Oled for utcomp 2
CChevy
Oled for utcomp 2
Postby CChevy » Sat May 13, 2017 6:29 am
Hey
It is possible to use this type of oled for the utcomp 2?
http://www.ebay.com/itm/Blue-2-2-128x32 ... lgo=origal
Re: Oled for utcomp 2
Postby ArT » Mon May 15, 2017 9:55 am
It should work with UTCOMP 2.0.4+ but connections are different and you will need to make adapter. You can try to do it on your risk but if you make mistake you can damage OLED panel and UTCOMP module, so I recommend you to use plug-and-play compatible OLED - it already has board with socket for UTCOMP tape.
