EGT TC AND AMPLIFIER CONNECTION
Argirisk3
Postby Argirisk3 » Fri Oct 20, 2017 4:51 am
Hi just wanted to make clear the connection method of the amplifier (single channel type k). Can you please let me know the proper connection to in and out sides? A diagram would be helpfull as well. No paper was included with amplifier as with the map sensor.
Thanks in advance.
IN
GND : A21 ???
VCC : A20 ???
TC +: To positive lead of TC ???
TC -: To negative lead of TC ???
OUT
GND: A21 ???
OUT 1: A8 ???
Re: EGT TC AND AMPLIFIER CONNECTION
Postby ArT » Fri Oct 20, 2017 7:51 am
Hi Argirisk3,
EGT-K datasheet: https://www.reveltronics.com/downloads/ ... eet_en.pdf
EGT tutorial: viewtopic.php?f=28&t=71
IN
GND : utcomp ground / vehicle ground
VCC : utcomp power supply (VCC range is +8..+32V, so +12V from car battery is fine for EGT-K)
OUT
GND: not required connection (please check above tutorial for more details)
OUT 1: AdcX (A8 is fine)
Hope it is clear. If you will have any further questions feel free to ask.
Argirisk3
Postby Argirisk3 » Fri Oct 20, 2017 12:56 pm
Thank you very much for your prompt reply. The paper with the specifications was already sent with the item, by mentioning it I meant the small with connection details like in the map sensor plastic bag, which I do not need now since you describe pretty well on your reply.
You are very helpfull. Cheers.
