Calibration for VDO 360009
baltik
Postby baltik » Mon Jul 30, 2018 8:14 am
Hello - I am interested in using a VDO oil pressure sender. I was curious if anyone has successfully calibrated this, since I do not see any reference numbers online
Re: Calibration for VDO 360009
Postby ArT » Mon Jul 30, 2018 11:27 am
Do you have output table for this sensor?
If not, you can measure it with manometer. Output voltage for 2 different pressures will be enough, e.g.
1 bar (atmospheric pressure) = ... ohm or volts
3 bar (or any other) = ... ohm or volts
