Wire size?
Timoes
Has thanked: 4 times
Wire size?
Postby Timoes » Thu Dec 20, 2018 11:15 pm
What type of wire size should be selected for the following sensors:
  • Oil and fuel pressure sensor 150 PSI 10 BAR
  • Oil and water temperature sensor NTC analogue
  • Temperature sensor for UTCOMP
  • EGT-K LMP (connection to UTCOMP)
  • EGT-K LMP (connection to EGT-K probe)
  • Cable to the original wiring harness or control unit of the car
With best regards, Timoes
Re: Wire size?
Postby ArT » Fri Dec 21, 2018 9:53 am
Hi Timoes, please take a look at page 11: https://www.reveltronics.com/downloads/ ... manual.pdf
Timoes
Re: Wire size?
Postby Timoes » Fri Dec 21, 2018 12:27 pm
Thank you very much. I should have read the manual again before I post here.
