More boost pressure options
axel
Postby axel » Sat May 23, 2020 1:06 pm
Hello
IS it possible to make more boost pressure options in the utcomp pro?
Like boost 1-2-3-4?
I´m using 3 boost sensor, but for now there is no good way, to display them.
I can call them oil and fuel pressure sensor, and then change the logos. But it seems a bit awkard.
Thank you
Re: More boost pressure options
Postby ArT » Mon May 25, 2020 6:52 am
At the moment there is no such feature. 6x EGT, 2x AFR but 3x boost? Where do you need them? :)
axel
Postby axel » Mon Jul 13, 2020 7:04 am
I need them for Before and after IC and a exhaust pressure :D
But I have already made my own logos, but it still shows up as other things (like oil pressure) ind datalogger and setup
