Lambda statt AFR
gmturbo
Lambda statt AFR
Postby gmturbo » Tue Apr 12, 2016 6:04 pm
gibt es eine Möglichkeit den Lamdawert anzeigen zu lassen anstatt des AFR-Wertes ?
mfg
gmturbo
Is there a way to display the lambda value instead of AFR-value?
mfg
gmturbo
Re: Lambda statt AFR
Postby ArT » Tue Apr 12, 2016 7:55 pm
1. You can activate oscilloscope screen and you will have nice chart (voltage in time, 50 samples per second) - low value means low lambda and high value means high lambda - it will work also with standard o2 lambda sensor (you do not need to have wideband o2 sensor)
2. You can rescale AFR to lambda (14,7 AFR = 1,00 lambda) and if you have PRO version than you can change also displaying icon to your own
