UTCOMP Pro on Megane MK1 1996
mike9h29
Postby mike9h29 » Fri Apr 07, 2023 7:55 am
I would like to ask if any have got the values for the below:
1) Engine Coolant Temp. Sensor
2) Outdoor Ambient Temp. Sensor (The one mounted on the mirror)
For the coolant temp. sensor I have found this:
20 Deg. - 3060 to 4045 Oms
40 Deg. - 1315 to 1600 Oms
80 Deg. - 300 to 370 Oms
90 Deg. - 210 to 270 Oms
As for the Outside temp, I cannot find any information. What I found is that the same sensor is used in a lot of cars, inclusing Peogeot, Citroen etc. It is a 2 wire sensor.
I would appreciate any help.
Many thanks, Mario
Re: UTCOMP Pro on Megane MK1 1996
Postby ArT » Fri Apr 07, 2023 9:21 am
Hi Mario, you need to measure voltage/temperature and scale it with excel:
viewtopic.php?f=28&t=58
first link in first post
mike9h29
Postby mike9h29 » Sat Apr 08, 2023 11:44 am
ArT wrote:Hi Mario, you need to measure voltage/temperature and scale it with excel:
Thank you. I will try the charts and will post an update.
Users browsing this forum: No registered users and 20 guests
