turbo pressure sensor calibration
Massimiliano
Postby Massimiliano » Thu Oct 19, 2023 9:59 am
Hi, I had a 2.5bar turbo sensor
Now I'm fitting a 3 bar turbo sensor.
Is this configuration correct?
I would like to read the real bars without the absolute
Thank you
I attach images
0281002996 utcomp.png (31.66 KiB) Viewed 144 times
Has thanked: 50 times
Been thanked: 149 times
Re: turbo pressure sensor calibration
Postby ArT » Thu Oct 19, 2023 7:22 pm
MAP sensor is absolute pressure sensor.
These values will give absolute pressure.
For turbo pressure, you can deduct 1.0 bar if you are living on sea level, so based on your calibration data it will be:
a = 0.66
b = -0,89 (with minus)
Massimiliano
Postby Massimiliano » Fri Oct 20, 2023 10:52 am
perfect thank you very much
my installation on clio rs3 swaps megane rs2
Postby ArT » Fri Oct 20, 2023 12:40 pm
Brilliant, small rocket :D
