turbo pressure sensor calibration
Re: turbo pressure sensor calibration
Postby ArT » Mon Feb 26, 2024 12:06 pm
Please share output table (voltage vs AFR) from manual so I can help.
Massimiliano
Postby Massimiliano » Mon Mar 11, 2024 4:05 pm
HI,
I downloaded the datalog, but I always have the turbo pressure at 0.6, but on the utcomp display it works up to 1.6bar
How come ?
Thank you
log_clio_rs3.zip
(22.81 KiB) Downloaded 794 times
Postby ArT » Tue Mar 12, 2024 9:25 am
I see in logs old data from 2023-11-26 and later from 2024-02-12. Seems like this is data with old setting and now datalogging is disabled. Please make sure that you have enabled data logging. If you are sure, please share me your utcomp settings file, I'll take a look.
Massimiliano
Postby Massimiliano » Wed Mar 13, 2024 9:44 am
hi Art, here is the utcomp data,
I had set manual recording, now I have set it to record every time I turn it on, is this correct? Thank you
UTCOMP_v3-8_settings_2024-3-13_9390.zip
(6.05 KiB) Downloaded 1460 times
Postby ArT » Wed Mar 13, 2024 11:27 am
I checked these settings and data logger is in manual mode (disabled by default). Just select in settings -> advanced -> datalogger recording when ignition swith is on and it will be working.
Massimiliano
Postby Massimiliano » Sun Mar 24, 2024 9:47 pm
hi, I tried, it records everything except turbo pressure... I don't understand why.. other info, what sensor can I use to see the exhaust gas back pressure?
Postby ArT » Mon Mar 25, 2024 9:58 am
Have you updated your settings with parameters I have marked on screenshot below? In settings file you have shared data logger was disabled and recording boost pressure was also disabled.
I've never measured exhaust gas back pressure, first you will need to find out possible pressure range, and secondly you will need find pressure sensor for such range which will operate also in this temperature range
Massimiliano
Postby Massimiliano » Mon Mar 25, 2024 11:55 am
Yes
Massimiliano
Postby Massimiliano » Mon Mar 25, 2024 2:10 pm
her
her
Postby ArT » Tue Mar 26, 2024 9:54 am
Now it's fine. Please share me your data logs file (.csv) from last 3 hours after settings were changed.
