Logging older engine
1948TC
Postby 1948TC » Fri Apr 05, 2024 12:41 pm
I have an older car (1948 MG TC supercharged). It has a distributor and carburettor, no ECU and few sensors.
As well as some of the things you have listed on here (eg: boost, EGt, etc) I want to monitor RPM, knock and ignition advance.
Is it possible to monitor and log these parameters? How would you recommend collecting the necessary signals?
Thanks in advance...
Has thanked: 53 times
Re: Logging older engine
Postby ArT » Mon Apr 08, 2024 12:12 pm
For RPM you will need any signal from hall sensor (you can assembly universal hall sensor with magnets https://www.reveltronics.com/downloads/ ... E4905L.pdf)
Knock and ignition advance unfortunately is not supported.
1948TC
Postby 1948TC » Wed Apr 10, 2024 5:30 pm
Thank you,
I get the rpm method. I think I could use this knock sensor which has a 0-5v output.
Would I be able to connect this to an analogue channel and log it?
https://phormula.com/product/phormula-k ... 08QAvD_BwE
Thanks,
Dave
Postby ArT » Thu Apr 11, 2024 11:10 am
Yes you can connect it to any AdcX input and use other value scaling which you are not using, e.g. connect is as EGT, AFR, Boost or anything else and scale it to your needs and then you can log it in datalogger.
1948TC
Postby 1948TC » Fri Apr 12, 2024 11:18 am
Thank you...
