Afr innovate lc2
Massimiliano
Afr innovate lc2
Postby Massimiliano » Sun Jul 13, 2025 10:29 pm
Hi, I installed the Innovate LC2 to read the AFR value. I calibrated it with the Innovate values and it works, but I noticed that both with the Zeitronix reader I use on the bench and with the Ecumaster EmuBlack that I have on my car, the values are not consistent. I have a difference of 0.8. Both Zeitronix and EmuBlack read 11.4/11.5 in WOT, and on the Reveltronico display with the Innovate LC2 I read 12.2 AFR. Is there a way to fix the reading? Thank you very much.
Re: Afr innovate lc2
Postby ArT » Mon Jul 14, 2025 10:00 am
Please share your AFR / Voltage output table and scaling parameters (a/b) you have used.
It can be calibrated with a/b parameters.
Massimiliano
Postby Massimiliano » Mon Jul 14, 2025 10:14 am
Hi, here it is.
Thanks.
Immagine 2025-07-14 101246.png (672.07 KiB) Viewed 17708 times
Postby ArT » Mon Jul 14, 2025 10:51 am
What is your voltage/afr output table? LC2 manual:
https://www.innovatemotorsports.com/wp/ ... Manual.pdf
Massimiliano
Postby Massimiliano » Mon Jul 14, 2025 11:04 am
I had entered these values,
I didn't do anything else.
Immagine 2025-07-14 110341.png (24.79 KiB) Viewed 17706 times
Postby ArT » Mon Jul 14, 2025 2:30 pm
Are you connected source signal from Output 1 or 2?
Massimiliano
Postby Massimiliano » Mon Jul 14, 2025 2:43 pm
ok sorry I didn't understand, I connected the 1, yellow, from 0 to 5v
Postby ArT » Wed Jul 16, 2025 9:46 am
Based on manual for signal from yellow wire it is
0V = 7.35 AFR and 5V = 22.39 AFR.
which gives
current AFR = 3.01 * voltage + 7.35
a = 3.01 b = 7.35
and it has to work correctly connected for Adc1 - Adc4.
Massimiliano
Postby Massimiliano » Wed Jul 16, 2025 10:18 am
It's connected to ADC4
A values = 3.01 b = 7.35
Yesterday I reprogrammed the Innovate LC2 with LM Programmer
I reset the sensor in free air as per the manual,
I checked again, and where EmuBlack gives me 14.4/5 AFR
On UTCOMP, I get 15/15.2 AFR and a voltage of 2.7 volts
If I connect the Zeitronic externally, it reads 14.5 AFR like EmuBlack
I saw that Zeitronix works differently:
21 to 9.5 AFR
At 0.15V, it's 9.7 AFR
At 3.27V, it's 21.0 AFR
So it has its own scale.
I tried lowering b, with a b value of 7.10, and it reads 14.4/14.5 AFR at idle like emublack.
I still have to test it on the road and in WOT to see if it reads 11.4 like emublack...
If so, can I keep the different B value?
Postby ArT » Thu Jul 17, 2025 10:06 am
It seems like your device is using different scaling.
are you sure about these values?
I'm asking beceause it will give scaling:
a = 3.62
b = 9.16
However, recommended scaling from innovate LC2 manual is a = 3.01 and b = 7.35.
e.g 2.7 volts for recommended scaling:
2,7*3,01 + 7.35 = 15.48 AFR
2.7 volts for your ecu scaling:
2.7*3.62 + 9.16 = 18.93 AFR
3.27V for your ecu scaling (checking):
3.27 * 3.62 + 9.16 = 21 AFR
