Prosport AFR/Lambda Controller
Dacti
Postby Dacti » Tue Sep 16, 2025 7:05 pm
Hi, I’m currently having problems with the calibration of my Prosport controller with my UTCOMP PRO.
The UTCOMP v3.5+ calculator opens as a locked document, so I can’t use it for my controller.
Could somebody please help me with the calculation for my values?
And how can I use these values to display them as Lambda?
I only have the values from this document on page 3/3:
https://www.merx-tuning.de/media/9f/cd/ ... nzeige.pdf
Thanks for the help and greetings from Germany
-Dominik
Re: Prosport AFR/Lambda Controller
Postby ArT » Wed Sep 17, 2025 9:39 am
Hi, based on pdf:
0V = 10 AFR
4.99V = 19,98 AFR
it will give params:
a = 2.0
b = 10.0
Dacti
Postby Dacti » Wed Sep 24, 2025 4:30 pm
Thank you for your help!
How did you calculate the values?
Postby ArT » Thu Sep 25, 2025 9:36 am
for MAP and pressures you can use simple calculator from UTCOMP app available in settings -> advanced -> pressure -> calculator and use AFR instead of bar.
