map sensor scaling
Snake4309
map sensor scaling
Postby Snake4309 » Mon Feb 16, 2026 9:11 pm
Hi. Wondered if anyone could assist scaling GM 3 bar sensor.
I have used settings I found online and also calculated myself.
I believe the sensor displays absolute pressure.
In my case 9psi at idle.
Is there a way for show - value in vacuum?
I have seen videos from other users doing this successfully.
I did read to subtract 1.00 from 'b'
But doesn't seem to have made a difference
Re: map sensor scaling
Postby ArT » Tue Feb 17, 2026 3:55 pm
Hello.
I sent you mail reply 2 days ago for this case. I'm quoting it here:
Please send me output table for this sensor, I'll need two values correlated with pressure (bar) for 0V (or 0.5V) and for 5V (or 4.5V).
On screen is 1.62V = 0PSI (0 BAR) and 5V = 28PSI (1.93 BAR) which should give:
a = 0.57 and b = -0,93 <---- it's for absolute pressure, b is with minus. If you would like to deduct 1atm pressure, b should be +0.07, so:
a = 0.57 and b = +0.07
Scaling is always in BAR, but displayed unit can be in PSI.
Snake4309
Postby Snake4309 » Wed Feb 18, 2026 1:25 am
Hey..
I apologise, maybe junk filter caught your email as can't see it. Thanks for your efforts, I do appreciate it.
I'm sure your correct with what you have written is correct.
I clearly misunderstood the - 1 bar part..
Once I have daylight here. I shall upload and see how it goes. Hopefully all will be well. I shall update you and upload voltage table if required.
Thanks.
Jake :)
Snake4309
Postby Snake4309 » Sat Feb 21, 2026 9:36 pm
Well to update. I believe map sensor is faulty. It seemed to work briefly displaying vacuum. then next time ran the car displayed some figures that definitely weren't correct.
So have ordered a Bosch Motorsport sensor to try instead.
Users browsing this forum: No registered users and 22 guests
