wideband controller
Dosrolux
wideband controller
Postby Dosrolux » Tue Sep 13, 2016 1:40 pm
I want to install a wideband controller.
On the Manual i see there is connection to a wideband controller.
Is there wideband controller you recommend to install? zeitronix, innovate with BOSCH LSU 4.9 sensor etc.......
Calibration needed?
Re: wideband controller
Postby ArT » Tue Sep 13, 2016 4:42 pm
UTCOMP supports all 0-5V controllers and you should connect it to any AdcX input. You will need also to know its output to scale it in utcomp's settings: viewtopic.php?f=28&t=58
Dosrolux
Postby Dosrolux » Wed Sep 14, 2016 2:42 pm
thanks for reply
The output data i have for the controller is 0 Volt = 7.35 AFR and 5 Volt = 22.39 AFR
Is that enough to introduce in your excel calibration?
Postby ArT » Wed Sep 14, 2016 9:07 pm
yes it is. Just enter in AdcX calculator:
0V -> 7.35 AFR
5V -> 22.39 AFR
and you will get data for UTCOMP:
a = 3,01
b = 7,35
