Temp sensor possibly reading high
Posted: Mon Nov 14, 2022 2:14 pm
I have been reading oil temperatures on my UTComp Pro higher than what I had before.
I am using NTC temp sensors from you, programmed to UTComp based on spec sheet included with sensor.
I would like to check gauges first as car has no mechanical problems, with coolant temp in normal range.
Is there any situation that would cause NTC sensor to read high, and how to check if so?
I have oil temp NTC sensor white wire connected to ADVCC B8 and the blue ground wire to a common ground in fuse area IIRC.
