calibrateion spartan 2 wideband controller
Posted: Sun Apr 30, 2023 2:00 pm
by Benjamin
Hello, can someone help me calibrate my spartan 2 wideband controller :oops: The attached files is all I could find from the manufacturer. I hope someone can help, thank you :D
Spartan_Lambda_Controller_2_User_Manual.pdf
(325.5 KiB) Downloaded 731 times
Spartan2_OEM_Manual.pdf
(447.32 KiB) Downloaded 584 times
Re: calibrateion spartan 2 wideband controller
Posted: Thu May 04, 2023 9:55 am
If Point 1 = 0V = 10.89 AFR and Point 2 = 5V = 19.02 AFR then:
a = 1.63 and b = 10.89
You have compatible calculator in settings -> advanced -> pressures or excel in this topic:
viewtopic.php?f=28&t=58
Posted: Fri May 12, 2023 2:19 pm
by Porschi
Guten Tag, ich hatte kontakt mit dem Hersteller und er hat mir diese Werte für den Controller mit der 4.9 Sonde gegeben.
AFR= ( 2*Volt) + 10
Lambda = ( 0,136* Volt) + 0,68
Posted: Mon May 15, 2023 11:06 am
Porschi wrote:
AFR= ( 2*Volt) + 10
a = 2.00
b = 10.00
