Utcomp system date
1948TC
Utcomp system date
Postby 1948TC » Wed Aug 07, 2024 9:17 pm
I disconnected the battery on my car while I did some engine work.
Now the Timestamp in the logger is the wrong date (see screenshot).
How do I check and update the system date?
Thanks,
Dave
Has thanked: 55 times
Been thanked: 163 times
Re: Utcomp system date
Postby ArT » Thu Aug 08, 2024 10:35 am
Hi Dave,
If you have connected keyboard and display, you can press longer SW1, go to clock/date settings from menu. There is also option to connect UTCOMP via USB cable, run UTCOMP windows app and save settings - after saving settings in UTCOMP Windows app via USB - time will be synchronised with current PC time
You can also install latest APK for android (still not official) where it should update time in UTCOMP everytime it connects
https://www.dropbox.com/scl/fi/ayg29k6t ... djv0g&dl=0
1948TC
Postby 1948TC » Thu Aug 08, 2024 1:06 pm
Thanks Art,
I have already connected my laptop. How can I check that the system clock is now correct?
Postby ArT » Thu Aug 08, 2024 3:11 pm
Only on display. If you have version without display (android only) it will be visible only in data logs.
