Prins LPG eVP-500 tank valve
Posted: Sun Apr 06, 2025 4:25 pm
by Vplus
i have a problem with the logging of the LPG status.
The tank valve gets activated with +12 volts, after a few seconds it gets reduced to 4,4 Volts.
The ut comp switches back to gasoline.
Is there a way to change the switch voltage ?
In the manual "(low state 0V - petrol, high state 3V and more - lpg)"
But in thesoftware it is 5 Volts ?
Thank you
Re: Prins LPG eVP-500 tank valve
Posted: Mon Apr 07, 2025 9:25 am
+4.4V is still fine for high state. Are you sure is it +4.4V between measured wire and vehicle ground?
It can not be software controlled, it's hardware input, low state <0.5V and high state >3V, so 4.4V is 100% fine and it should work.
Posted: Mon Apr 07, 2025 12:40 pm
by Vplus
Thank you for your request.
Maybe it's pwm Controlled...
I will messure again today.
When I look at the Windows software it Switches between on and off...
When I want to read the lpg Status with the gas injectors, the Display is blinking :/
Thank you for your help
Posted: Mon Apr 07, 2025 4:56 pm
by Vplus
It is an pwm signal for the tank valve :/
how do I get it to work?
Posted: Tue Apr 08, 2025 9:15 am
Change signal source from LPG electrovalve, it will be constant +12V/0V
Posted: Tue Apr 08, 2025 12:26 pm
by Vplus
There was no way to do it switch the tank valve circuit.
Now I have A10 an A11 on the gasoline and the lpg injector...
Everything work fine.
Posted: Wed Apr 09, 2025 12:24 pm
Ok, usually this switch is outside ECM.
You can also check C3 signal T-ECT (or M1), seems like it may be ON/OFF controller
