temp sensors
Posted: Mon Sep 05, 2016 2:31 pm
hi
i run into a small issue with the setting of my UTCOMP
i'm going to use 2 OE sensors (powered from ECU) so i will connect them to pins b2 & b3
now my problem is that i want to connect another NTC sensor and use it in pin a20 which will power it but i can't program it in the software
is there any solution for that?
thanks in advance
thanks in advance
