It should work with UTCOMP 2.0.4+ but connections are different and you will need to make adapter. You can try to do it on your risk but if you make mistake you can damage OLED panel and UTCOMP module, so I recommend you to use plug-and-play compatible OLED - it already has board with socket for UTCOMP tape.
