Tank Level Sensor
Posted: Fri Jun 02, 2017 8:11 pm
by Inzan3
Hello, i have a little problem. My Tank Level Sensor is a Pull-down type ( measure resistance to Ground) and UTComp needs Pull-up to 5V. It isnt possible to use it as Pull-Up what can i do?
Re: Tank Level Sensor
Posted: Sat Jun 03, 2017 11:08 am
It's fine because you are measuring voltage level directly, so you will have e.g. ~5V on tank empty and ~0V on tank full and it will work too.
Posted: Sat Jun 03, 2017 7:25 pm
by Inzan3
So the Tank gauge supplies the 5V?
Posted: Sat Jun 03, 2017 8:32 pm
In most cases voltage is in range of 0-5V. In older cars it may be 0-12V. I'm talking about stock sensors connected to AdcX input (if you want to connect additional sensor than it should be connected to AdcVccX and it should be minimum 1k ohm resistance range)
