EGT TC AND AMPLIFIER CONNECTION
Posted: Fri Oct 20, 2017 4:51 am
by Argirisk3
Hi just wanted to make clear the connection method of the amplifier (single channel type k). Can you please let me know the proper connection to in and out sides? A diagram would be helpfull as well. No paper was included with amplifier as with the map sensor.
Thanks in advance.
IN
GND : A21 ???
VCC : A20 ???
TC +: To positive lead of TC ???
TC -: To negative lead of TC ???
OUT
GND: A21 ???
OUT 1: A8 ???
Re: EGT TC AND AMPLIFIER CONNECTION
Posted: Fri Oct 20, 2017 7:51 am
Hi Argirisk3,
EGT-K datasheet: https://www.reveltronics.com/downloads/ ... eet_en.pdf
EGT tutorial: viewtopic.php?f=28&t=71
IN
GND : utcomp ground / vehicle ground
VCC : utcomp power supply (VCC range is +8..+32V, so +12V from car battery is fine for EGT-K)
OUT
GND: not required connection (please check above tutorial for more details)
OUT 1: AdcX (A8 is fine)
Hope it is clear. If you will have any further questions feel free to ask.
Posted: Fri Oct 20, 2017 12:56 pm
by Argirisk3
Thank you very much for your prompt reply. The paper with the specifications was already sent with the item, by mentioning it I meant the small with connection details like in the map sensor plastic bag, which I do not need now since you describe pretty well on your reply.
You are very helpfull. Cheers.
