Is there a way to read out the maximum EGT Temperature ?
Gibt es eine Möglichkeit die Maximale EGT Temperatur auszulesen ?
MfG
GMTurbo
gmturbo wrote:The system I have installed in a customer car, so both options for reading are not possible for me. Maybe you can read this honest D-Bal review and integrate that into the software, so that the maximum temperatures (water, oil, EGT) are readable. Reading via PC software would be enough.
Das System habe ich in einem Kundenauto verbaut, daher sind beide Optionen zum Auslesen für mich nicht möglich. Eventuell kann man das ja in die Software integrieren, so das die maximalen Temperaturen (Wasser, Öl, EGT) auslesbar sind. Auslesen über PC-Software würde ja reichen.
MfG
GMTurbo
LesterHuf wrote:Is it possible that the alerts aren't working properly? Because I have a nagging feeling that this is the case in my case. How do I verify that everything is working correctly?
