Turbo Boost/ Oil Pressure/ Oil Temp
Posted: Sat Nov 10, 2018 3:40 pm
by g300d
Hello, I just purchased a UTCOMP PRO.
For turbo boost I have the Bosch 5V 3 Bar MAP sensor.
For oil pressure I have 150 PSI/10 Bar 5V pressure sensor.
For oil temp I have Oil and Water temp sensor NTC analog.
I would like to confirm wiring for these.
For MAP SENSOR:
Positive to VCC (A6 or A18 or B6 or B12)
Ground to GND (A4 or A16 or B4 or B10)
Signal to Adc1-4 (A8 or A9 or B2 or B3)
For 5V OIL PRESSURE SENSOR:
For NTC ANALOG OIL TEMP SENSOR:
Positive to AdcVcc1-2 (A20 or B8)
Ground to BODY GROUND
Are these correct?
Re: Turbo Boost/ Oil Pressure/ Oil Temp
Posted: Sat Nov 10, 2018 3:55 pm
Yes it is correct :-)
For MAP and Oil pressue sensors you can also use vehicle ground if you have good connection point next to sensors.
Posted: Sat Nov 10, 2018 5:22 pm
by g300d
Thank you, I appreciate the very quick reply. :)
Additionally, I would like to display coolant temperature on UTCOMP PRO, taking data from existing coolant temp sensor.
I understand I can tap positive line of existing sensor and attach to Adc1-4, but I must scale for output to be correct.
Would you happen to have data already on my existing sensor to scale it properly?
This is for a 2010 Subaru Legacy 2.5 GT 5EAT, but the sensor is probably the same as all Subaru 2.5 EJ255 turbo models.
Posted: Sat Nov 10, 2018 5:37 pm
If you have diagnostic interface then the best method is to make readings (voltage on sensor + temperature) and then you can use these readings to scale it with utcomp. Please take a look for excel calculator in first post: viewtopic.php?f=28&t=58
If you do not have diagnostic interface then you can read temperature from dash and voltage from voltmeter. It will be less accurate (because you can not read temperature below 50-60C) but it will work too.
ps. voltage on sensor is also visible in UTCOMP app (readings tab)
Posted: Sat Nov 10, 2018 6:14 pm
by g300d
I will review the link and give it a try, again, thank you. :)
