I'm considering switching out the mechanical fan to an electric one. That will necessitate the need for a fan controller, which I think the UTCOMP can probably do but I want to confirm.
Using pin B7 (DigOutUser), I can control a relay that will engage the fans. What I'm not 100% I understand the regulation mode configuration. I need to turn ON the fans at say 185F and then have them turn OFF when temp reaches 170F. Is that possible?
Matthew
PS - As the fans have a high current draw, I'm wondering if this would be an appropriate relay?
https://www.amazon.com/5-12V-High-power ... B00ZC4Z0T0
OR
https://www.newark.com/te-connectivity/ ... dp/66F6688
