Six 0-5v Analog Signals: EGT x 4, Wideband AFR & Manifold Pressure
Posted: Mon Sep 23, 2019 11:20 pm
Is it possible to connect six 0-5v analog signals to the UTComp-Pro? If so, what is the best way?
I have one K-type thermocouple in each of the four header tubes. Each thermocouple is connected to the proper terminals of the Reveltronics EGT-K 4-Channel Thermocouple Amplifier. It makes sense to connect the four outputs from the EGT-K Amplifier to the four AdcX 0-5v analog inputs (A8, A9, B2 and B3).
However, I need to connect two more 0-5v analog outputs to the UTComp-Pro: 1x Wideband AFR output and 1x Manifold Pressure output from my AEM Wideband Failsafe Gauge.
I suppose the Wideband AFR (or Manifold Pressure) output from the gauge can be connected to the Adc5 0-30v analog input (B9). Will this work well? Is there a better option?
In any case, there would still be one more 0-5v analog signal that I need to connect. Is this possible? If so, what are my best options?
EGT 1 > Adc1 (A8)
EGT 2 > Adc2 (A9)
EGT 3 > Adc3 (B2)
EGT 4 > Adc4 (B3)
WB AFR > Adc5 (B9)?
Manifold Pressure > ???
Thank you,
Kirk
EGT 1 > Adc1 (A8)
EGT 2 > Adc2 (A9)
EGT 3 > Adc3 (B2)
EGT 4 > Adc4 (B3)
WB AFR > Adc5 (B9)?
Thank you,
Kirk
