Is Utcomp Pro the right one?
Posted: Tue Nov 26, 2019 11:13 pm
by Onevplus
Hi there,
I'm lookin for a solution to get my values right on my Radio Display.
Radio is an Android 9.1 with otg USB so this should work.
I got a few values to grab.
7times Egt
1time fuel pressure
1time oil pressure
1time oil temp
1time boost
2times air temp intake
2times wather temp
the Best way to get it All? Alternativ 1time egt if it isnt possible to get All.
Or is there any other solution known?
Re: Is Utcomp Pro the right one?
Posted: Thu Nov 28, 2019 12:38 pm
UTCOMP-PRO has 7 analog inputs (4x 0-5V, 2x0-5V with pullup for NTC sensors and 1x 0-30V). Additionaly you can connect 4x DS18B20 temperature sensors. Can't connect all these values you mentioned with single module, but most of it, e.g.
Adc1 fuel press (0.5-4.5V sensor)
Adc2 oil press (0.5 - 4,5V sensor)
AdcVcc1 Oil temp (NTC sensor)
Adc3 boost (MAP sensor)
Adc4 egt (EGT-K output)
AdcVcc2 water temp 1 (NTC sensor)
Adc5 - left unconnected
DS18B20 bank 1 - air temp from DS sensor 1
DS18B20 bank 2 - air temp from DS sensor 2
There is still water temp 2 to connect, it's recommended to use NTC sensor and connect it to AdcVccX but we are out of these inputs so you can alternatively use DS18B20 bank 3 and assembly it on thread, please take a look at this example: viewtopic.php?f=28&t=120
Posted: Thu Nov 28, 2019 8:09 pm
by Onevplus
So if i understand it right i'll need UTComp Pro and EGT-K and Sensors to get my information's
1 time Egt
1 time fuel pressure
1 time oil pressure
1 time oil temp
1 time boost
2 times air temp intake
2 times wather temp (one on the DIY way)
all right thanks @ArT
Posted: Thu Nov 28, 2019 10:11 pm
exactly :-)
