porsche 996 piggypag sensors
Posted: Fri Feb 14, 2020 10:50 pm
Hello i have a 996 carrera and i want to "steal" signal from the oem sensors for water and oil temp.. Is there any possibility doing that to confuse the signal going to ecu and have a false reading???? Also as i can undertand the oem sensors are analog ntc sensors and i have to calibrate them. Where i can found the values to do the proper table???
or how what i have to measure to find the values i am looking?? sensors are in the photos attached.. the oil sensor is a bit weird because it is oil level sensor in the same time...
