AFR calculation / UT Comp Pro Zadatech AFR
Posted: Sat Feb 29, 2020 8:39 pm
I bought the UT-Comp Pro and the AFR Wideband Probe by Zadatech (Manual: http://zada-tech.com/dyn/zadatechwidebandafr.pdf)
Can somebody help me with the recalculation? The manual says: "To convert from voltage to AFR use
the formula: V*15.04/5+7.35. "
What values should I put in "a" and "b" in UT Comp?
Thank you in advance for help..
