Now I am wiring to my car the UTComp unit and I have a question abouth the Digiout after read the manual and the next link,
viewtopic.php?t=172
Is possible to activate or deactivate manually the relay too? For example, I can put that water cooling fan activate his function when engine temp was 100degrees, BUT, can I can activate manually without waiting for it to reach the previously programmed degrees?
Also.
There is possible to programe another function that doesn´t cames on the software? For example, led light when engine was at 7000rpm?
