Rotary setup AFR / 2xEGT / Boost Oil Fuel Press / Oil Water IAT Temp
Posted: Sun May 31, 2020 2:41 pm
I'm really interested for the UTComp, but I have somes questions before
I want to use it on a rotary engine (RX7 FD3S)
1) Did The fuel consumption will work ?
Because on this engine we have 1 primary injectors (work everytime) and 1 secondary injectors (only for boost) for the same rotor
2) For the setup, here is informations I need :
Oil pressure
Fuel pressure
Oil temperature
Water temperature
Intake temperature
EGT on front rotor
EGT on rear rotor
AFR
Boost pressure
Can the UTComp handle this ?
I read the others posts and you said we can use the ADc5 (0-30V) with input 0-5V so that is OK But I still need one more input for Oil temperature because I don't want digital sensor for this (Oil temp can reach 160°C)
So here is what I've planned :
Oil pressure : AdcVcc 1 with power and ground from DS18B20C
Fuel pressure : AdcVcc 2 with power and ground from DS18B20D
Oil temperature : Adc 5 with NTC sensor
Water temperature : DS18B20A
Intake temperature : DS18B20B
EGT on front rotor : Adc 1
EGT on rear rotor : Adc 2
Boost pressure : Adc3
AFR : Adc 4
But to use AdcVcc 1 and 2, I seen I need to remove the little resistors R14 and R21, right ?
Maybe there is another solution without removing these 2 resistors ?
If no, is it possible to remove this resistors in your shop before to send it ? I don't feel comfortable with this operation
What about the warranty if it's removed ?
Thanks a lot
Thomas
Oil pressure
Fuel pressure
Oil temperature
Water temperature
Intake temperature
EGT on front rotor
EGT on rear rotor
AFR
Boost pressure
AFR : Adc 4
Thanks a lot
Thomas
