Splash tutorial
Posted: Sun Dec 13, 2020 4:15 pm
by Pistou
Does anyone know how to convert any image to greyscale 16 bit 256*64 as requested by UTCOMP PRO ?
Thank you !
Re: Splash tutorial
Posted: Mon Dec 14, 2020 11:03 am
Just convert it to grayscale 256x64 using any graphic software, UTCOMP software will convert it to 16-bit compatible format during importing.
Re: Splash tutorial
Posted: Fri Jan 01, 2021 10:59 am
by RaceR
hi,
i have a problem to modify the splash screen.
I have a good format for my user splash screen, but if i want to choose sample splash screen, it don't work too...
Do you have an idea why it don't work??
Re: Splash tutorial
Posted: Fri Jan 01, 2021 11:19 am
by RaceR
I think the software don't save the .bmp file to the UTCOMP
I have always this screen (with user or sample splash):
- fail splash.jpg (118.47 KiB) Viewed 17979 times
Re: Splash tutorial
Posted: Fri Jan 01, 2021 3:14 pm
by RaceR
I have found one solution.
I modify Flash memory to change the splash screen.
This method work perfectly.
Re: Splash tutorial
Posted: Mon Jan 04, 2021 10:26 am
This is default user bitmap. You can also change it in UTCOMP windows app: settings > preferences -> splash screen, next you should select user graphic 256x64 and load BMP file from external file and next you need to remember to check checkbox to save new bitmap with settings (otherwise it will not upload with saving settings)
Re: Splash tutorial
Posted: Mon Jan 04, 2021 4:11 pm
by RaceR
ArT wrote:This is default user bitmap. You can also change it in UTCOMP windows app: settings > preferences -> splash screen, next you should select user graphic 256x64 and load BMP file from external file and next you need to remember to check checkbox to save new bitmap with settings (otherwise it will not upload with saving settings)
Yes i know, i do it but it don't work.
I only can change it if i modify the default user bitmap... I don't understand
