AFR installation
Posted: Fri Dec 18, 2020 3:20 pm
by Pistou
I'm willing to retrieve signal from o2 sensor on my car but I understand I need a controller to get 0-5V voltage.
Can you advise a simple cheap controller?
Re: AFR installation
Posted: Fri Dec 18, 2020 10:07 pm
For AFR you will need wideband o2 sensor. Standard o2 sensor only will give you information about lean/reach mixture. Black wire is 0-1V signal as I remember.
If you sure that it's wideband o2 sensor, then controller will be required. But controller depends on type of O2 sensor. E.g. for BOSCH LSU 4.9 I recommend Innovate LC-2, but it can be any controller with 0-5V output.
Posted: Sat Jan 23, 2021 1:50 pm
by Toomas
Posted: Sun Jan 24, 2021 8:41 pm
Not tested it and can't find datasheet/manual on site. Does it have 0-5V AFR output?
Posted: Mon Feb 15, 2021 12:30 pm
by Toomas
Hi mate, and sorry for late reply, its but hard to get the information! Here is the connection diagram
Posted: Tue Feb 16, 2021 8:51 am
On schema is "0-5V OUTPUT" to display - the same output will work with UTCOMP AdcX input but you will need to know also scaling (how 0-5V output is scaled to AFR value in your controller)
