Can I use 1 sensor for UTCOMP + ECU ?
Posted: Sun Feb 07, 2021 10:23 am
I wanted to know if I can use 1 sensor (AFR, Pressure, Temperature NTC and Digital) for the UTComp and also for the ECU ?
I'm actually using an Apexi PowerFC on my car, and it can not read all the sensors that I need
So my plan is to buy an UTComp Pro to get all the informations that I want, until here there is no problem
But in the Future, I would like to use something better than the powerFC, for exemple Haltech 2000, or Link ECU G4+, and so my questions are :
1)Can I use all the sensors from the UTComp with my ECU (I think Yes)
2)Can I use the sensors (AFR, Pressure, Temperature NTC and Digital) for ECU and for UT Comp in the same time (to keep the UTComp Screen to display values)
3)If it's possible, can you explain me the wiring for each sensor ?
-Voltage Sensor using Adc 0-5V, I just have to split the return signal cable ?
-NTC Sensor using AdcVcc, for these one, I've read I have to split only the voltage cable and calibrate the UTComp in voltage<->readings, right ?
- For the DS18B20, i don't know it it's possible to use them on ECU + UTComp
- For AFR, also don't know, I plan to use an AEM UEGO Gauge with Bosch 4.9 sensor, so i will use the output 0-5V from the gauge to get the informations on UTComp, but can I split the output for ECU also ?
- For EGT, it work as the 0-5V sensor ?
Thanks for your help !
Thomas
Thomas
