Cooler fan input A21
Posted: Wed May 19, 2021 12:42 pm
by Scobo
Hi, is there possibility to have symbol / icon of fan when input is true and fan running?
Re: Cooler fan input A21
Posted: Wed May 19, 2021 2:19 pm
Engine temperature icon is changing from termometer to fan when cooler is enabled
Posted: Wed May 19, 2021 3:24 pm
by Scobo
Aha, and if it will not, what should I do? When connected with usb-UTCOMP from Readings I can see A21 gets voltage and status changes.
Posted: Thu May 20, 2021 1:37 pm
Please check if you have activated FAN in settings -> inputs/outputs -> pin a21 -> cooler
Now activate engine temperature on any screen and when you switch cooler input it will change icon from temperature to cooler
If it's not working please share me your utcomp settings file, I'll import it and check it.
Posted: Thu May 20, 2021 3:05 pm
by Scobo
UTCOMP_v3-8_settings_2021-5-20_104539.zip
(3.77 KiB) Downloaded 874 times
I'm using 10. User (2) as default screen and that window oil symbol will not change, neither on DigOutUser control window.
Posted: Fri May 21, 2021 12:43 pm
Ok located where is the issue. You have selected OIL TEMPERATURE, but fan is for engine - please activate ENGINE TEMPERATURE icon
Posted: Fri May 21, 2021 12:54 pm
by Scobo
Aha, okay. Yes I'm measuring motor oil temp and control fan according that...so then clear. Thnx a lot for your great support!
Posted: Tue May 25, 2021 3:36 pm
by Scobo
Still one question...
as I have air / oil cooled engine and measuring OIL TEMP - but as understood I should use ENGINE TEMP to get this fan running symbol...
I can swap ENGINE TEMP icon with OIL TEMP on "HARDWARE" -tab with "#FLASH" authorisation code, right?
So can you please confirm if this is correct > replace 32x16_temp_engine.bmp - 32x16_oil.bmp ?
So address: 0x6700 ( #define SPI_FLASH_ADDR_ICO_32x16_TEMP_ENGINE) to be replaced with 32x16_oil.bmp, right?
Thnx!
Posted: Tue May 25, 2021 6:03 pm
Yes you can replace icon, but you can define your oil temperature as engine temperature, it will be different icon but it will work without any mods.
