digoutuser/diginuser
Posted: Thu Jun 17, 2021 4:47 pm
hello guys!
I would like to use the digoutuser +5v pin in my utcomp pro to power a solenoid valve at a certain rpm. diginuser(pin B1) is described as a RPM port so I connected it to the camshaft position sensor to have a rpm signal, in advanced setting it is possible to set the number of signals per revolution so I should be able to set the instrument reading to the right value. I need to set the digoutuser(pin B7) so that it powers the valve once 1700 rpm are reached and here I find 2 problems: first problem is high threshold seems to have top value at 800 but may be I could solve the problem setting the hall sensor reading in a different way, the second and main problem is the digoutuser does not have "RPM" in the signal source menu. the digoutuser signal source menu has vehicle speed as a possible reading from a hall sensor but I can't find how to activate that function and which channel in the menu should be enabled to have that feature working. has anybody already figured out a problem like this? thanks!
Nico
Nico
