Low fuel level alert
Posted: Wed Mar 16, 2022 9:32 am
by amirtiti
I'm looking for a possibilty for the UTCOMP to alert on low fuel level based on the low fuel warrning light without any connection to the fuel level sensor...
Just a simple on/off input to alert on low fuel
The alert will be once for any ignition cycle...
Is there any option for that?
Thanks in advance
Re: Low fuel level alert
Posted: Wed Mar 16, 2022 10:58 am
There is no such option in UTCOMP but there is workaround. You can connect signal to AdcX input and scale it with not used value (e.g. AFR, EGT or other). Then scale it e.g. 0 = low fuel, above 100 = fuel ok and then set alert ón AFR/EGT/etc depends on what you have selected) to alert below 10 or so so it will trigger everytime fuel is low.
