Correct re-flash procedure for corrupted icons
Kaldek
Has thanked: 7 times
Been thanked: 5 times
Postby Kaldek » Tue May 10, 2022 10:30 am
Hi Artur, on my UTCOMP some of the icons are corrupted. How can I reflash the module so that all of the icons are pushed to the flash storage again?
Re: Correct re-flash procedure for corrupted icons
Postby ArT » Thu May 12, 2022 12:13 pm
Hi Kaldek, in UTCOMP application when you connect UTCOMP use shortcut CTRL + ALT + SHIFT + R and next CTRL + ALT + R and confirm, it should load default settings with default flash image.
Please remember to make backup of settings because all settings will be restored to default
