Fuel level sensor, resitance / ohm
Posted: Tue Jun 21, 2022 1:04 pm
Hello.
So im starting to get everything in order on my Porsche 944 installing the ucomp 3 pro.
However i am having a little issue on how i can use the oem fuel level sensor.
I connected it to ADC2, then enabled this in the software as an fuel level sensor (pb on)
However how can i calibrate this? as its an resistor signal?
I know the following:
Level Resistance (Ohms)
RESERVE 63.2ohm
1/4 42.2ohm
1/2 21.2ohm
3/4 8.6ohm
FULL (1/1) 2.8ohm
from what i can see in the advance tab, its only voltage adjustment for empty and full.
any ideas on solution?
RESERVE 63.2ohm
1/4 42.2ohm
1/2 21.2ohm
3/4 8.6ohm
FULL (1/1) 2.8ohm
