Table of contents + interesting assembly aspects
Posted: Mon May 25, 2015 8:52 pm
I. Interesting aspects of assembly:
- Display assembly in instrument cluster: 1, 2, 3, 4, 5
- Display enclosure from 3D printer: 1, 2
- Other inspiration for nice display assembly: 1, 2, 3, 4
- Thermal isolation for temperature sensors: 1
- Board computer control from steering wheel shifter: 1, 2
- Fuel consumption in common-rail diesel with electromagnetic injectors (using CR-PWM): 1
- Assembly in motorbike: 1
- Gear indicator - methods of measurement and calibration
- Additional sensors assembling for Turbo/Boost Pressure, Oil pressure, EGT, Oil temperature, Coolant temperature etc.
- Analog sensors - scaling analog sensors (resistance, voltage or NTC)
- Additional oil temperature sensor and oil pressure sensor 0-10 bar from Auto Gauge
- DS18B20 digital temperature sensors tips & trick for assembling
- Exhaust Gas Temperature (EGT) measurements tutorial
- Digital output control (e.g. relay switch) based on temperature or speed
II. Example of assembly in vehicles:
- Alfa Romeo 147 JTD 16V M-JET
- Audi A4 B5
- BMW E36 coupe 1.8is + LPG
- Chevrolet Lacetti 1.6
- Daewoo Lanos 1.6 16v
- Fiat Punto II 16v
- Fiat Stilo 1.2 Turbo Ecumaster DET3
- Honda Accord CL7 2.0 + LPG
- Honda Civic (6gen.) (1995-2001) - incl. also Rover 414, 416, 418, 45
- Honda Civic (MK6) (ang.)
- Mitsubishi Galant 2.5 V6 - display in instrument cluster
- Mitsubishi Galant 2.5 V6 - display in place of factory watch
- Mitsubishi Legnum/Galant VR4 UTCOMP-PRO assembling video
- Opel /Vauxhall Vectra-B 1.6 + LPG
- Peugeot 206cc 1.6 16V
- Seat Ibiza MK3 SDI
- Subaru Impreza GD
- Suzuki DL650 V-Strom
- Toyota Corolla (E11) 1.3 (4E-FE)
- Volvo V40 1.8 (2001)
Did you wrote or found UTCOMP assembly at other forum? Please share it to others in this thread! Thank you!
