Update v3.7 for UTCOMP-3 and UTCOMP-PRO
Has thanked: 20 times
Been thanked: 95 times
Postby ArT » Thu Nov 29, 2018 1:38 pm
And here it is.. v3.7 update for UTCOMP-3 and UTCOMP-PRO 8-)
Update is free for all and it will work with all UTCOMP-3 and UTCOMP-PRO modules. You can download latest UTCOMP software from REVELTRONICS UTCOMP product page
Changelog v3.7 for UTCOMP-3 and UTCOMP-PRO
  • added support for UTCOMP Android v0.1.3 (with data-logger feature) - please take a look at UTCOMP Android app on forum
  • added conditional alert for EGT and AFR (alerts can be ignored when boost pressure is below 0,3bar)
  • added summary screens (current and last) to TRIP screen (press SW3 to switch)
  • fixed digits refreshing for few areas
  • fixed bug when alert triggered during stats resetting
Your feedback
I would like to use this oportunity to encoruage you to write a review about UTCOMP-3 or UTCOMP-PRO on product site, UTCOMP Facebook profile, UTCOMP Android app (Google Play) or in any place on the internet 8-) If you have suggestions for next updates please share it on forum in dedicated topic. Your opinion is important to us! Thank you! :)
Update v3.6
Update v3.5
Update v3.4
Update v3.3
Update v3.2
Re: Update v3.7 for UTCOMP-3 and UTCOMP-PRO
Postby ArT » Mon Apr 29, 2019 12:58 pm
There is already available v3.7.1 minor update for interested users:
- speed measurement up to 999 km/h or mph (before it was 255 kmh or mph)
- added settings for analog inputs averaging (it can be customized to make measurements faster or more stable):
- added manual data-logger (logging can be enabled or disabled from menu) with current memory state:
If you are interested with above functions then you can update your UTCOMP-3/UTCOMP-PRO manually.
UTCOMP-3 v3.7.1:
https://www.dropbox.com/s/5byoyhvxu227h ... 2.zip?dl=0
UTCOMP-PRO v3.7.1:
https://www.dropbox.com/s/kt0co0ru3qry6 ... 2.zip?dl=0
Please first update device firmware (check readme file for instruction) and next replace required files in software installation folder.
Kaldek
Has thanked: 4 times
Postby Kaldek » Tue Apr 30, 2019 1:46 pm
Hi Artur, if we install 3.7.1 will it cause any issues with later updates such as 3.8?
Postby ArT » Tue Apr 30, 2019 2:36 pm
Don't worry, there will be no problems
Kaldek
Postby Kaldek » Wed May 01, 2019 4:38 am
Thanks. I installed 3.7.1 and greatly appreciate the ability to slow down my temperature readings.
