UTCOMP Android app (developement progress)
Has thanked: 18 times
Been thanked: 92 times
Postby ArT » Mon Nov 27, 2017 2:49 pm
Download:
About UTCOMP Android:
Android application is additional layer for user interface for UTCOMP-3 and UTCOMP-PRO modules. It will work with devices with Android 5.0 (and latest) and equipped with USB OTG. UTCOMP module is responsible for reading and processing data, while Android App is working as additional user interface (UTCOMP-3/PRO module is always working in background - you do not have to run android app for data processing). This is simple app where functionality is limited in comparison to UTCOMP features with dedicated graphic display and windows app - UTCOMP dedicated display and windows app are still required to get all features and change all settings.
What's working (2018-11-29):
  • USB communication and data synchronization with UTCOMP-3/UTCOMP-PRO (v3.6+),
    Please note! If you are using v3.5 of UTCOMP then you will need to update it to latest version (v3.7 at the moment)
  • dashboard with user selected digital widgets (you can choose all data available in UTCOMP user screens + TRIP data),
  • possibility to add multiple dashboards with user selected data,
  • possibility to configure XY grid (X rows, Y columns) for each dashboard,
  • possibility to change widget text and icon size,
  • compatible with portrait and landscape modes,
  • saving user configuration (as application preferences on android device),
  • stats management (reset general stats, reset trip data, change fuel level, change fuel costs),
  • displaying alternative units (mph, mpg, farentheits, psi, etc.) based on settings in UTCOMP,
  • alert system (based on alerts configuration in UTCOMP),
  • peak values (min/max for each gauge on dash),
  • demo mode (possibility to load random data when UTCOMP is not connected),
  • bug report from application,
  • translations
  • data-logger (import data from UTCOMP-PRO and draw charts) - NEW
TODO (maybe someday 8-) ):
  • basic UTCOMP settings management (configure inputs/outputs, vehicle data etc.)
  • extended UTCOMP settings management (preferences, advanced settings and other settings from Windows App)
  • alert manager + alert settings,
  • service/inspection + settings,
  • UI preferences (change color, dashboards titles etc.),
  • other type of widgets (e.g. graphical widgets),
  • firmware update from Android,
  • bluetooth communication
Latest news:
  • 2018-11-29: added v0.1.3 beta version to google play (link above)
Re: UTCOMP Android app (developement progress)
Postby ArT » Fri Dec 29, 2017 1:54 pm
Almost done first release for testers. We will send mails to subscribers soon with v3.6 update for UTCOMP, UTCOMP Android APK installer and all details.
At this stage we will NOT share it in official channels - if you would like to receive app please subscribe to the list in first post.
edit 2017-12-30: UTCOMP Android v0.1.0 alha released. Emails with apk installer sent to subscribers.
Postby ArT » Sun Jan 14, 2018 6:14 pm
v0.1.1 released.
Changes:
  • fixed outside temperature missing values,
  • display sleep mode off for android when using dashboard,
  • added peak values for gauges (min/max),
  • added alerts (based on alert configuration from UTCOMP)
  • demo mode (possible to load random data when device is not connected)
simple warning (oil temperature <50C)
simple alert (egt >900C)
Postby ArT » Sat May 12, 2018 9:21 pm
UTCOMP Android app finally added to google store (v0.1.2). This is beta version, but available for all (link in first post). Please note that it requires UTCOMP-3/PRO v3.6.x module to work (link to v3.6 update also in first post).
Postby ArT » Thu Nov 29, 2018 2:09 pm
Just released UTCOMP Android v0.1.3 (should be already available in Google Play).
Added Data-Logger feature:
- import data logs from UTCOMP-PRO or from external .csv file
- export data logs to external .csv file
- visualize data logs on charts
v0.1.3 requires UTCOMP-3 or UTCOMP-PRO in version v3.7 (please remember to update your UTCOMP module with PC and Windows application if you have older version).
You can install app and check how it works without connection to UTCOMP-PRO (it will load example logs).
It will be great if you write a short review about UTCOMP Android in Google Play or just rate it. Thanks! :-)
I hope you will like it :-)
User avatar
Talon
Contact:
Postby Talon » Sun Nov 10, 2019 10:32 pm
it will great if that have possibilities to:
- reset the comp (sometimes my utcomp do stuck - and only what help - is connecting to PC and do "Restart the module")
and mainly to set DATE/TIME from it! (date/time always do reset when disconnect the battery... - what i ofted have to do for different reasons)
Subaru Forester SG9/07MY/petrol/2.5XT/300+HP/EJ255 [UTCOMP-3]
