Pistou
Been thanked: 3 times
Postby Pistou » Fri Mar 26, 2021 8:01 am
Hello, So you need a specific sensor to feed an ADC and you are looking for the transfer function to be adapated in UTC ?
Thx
Sergej
Postby Sergej » Tue Jun 01, 2021 8:40 am
I have a proposal to have an oil pressure warning based on engine speed threshold instead of Voltage. For me the buzzer beeps all the time when I shut the engine off or almost stall it at slow maneuvering.
toho
Has thanked: 6 times
Postby toho » Mon Dec 20, 2021 1:27 am
Suggestions:
- Option to use one ADC Input for TPS (throttle position Sensor). For example, two calibration fields: one field e.g. 1V = 0% and second field 5V = 100%
A must be for data logging
- Speed in the acceleration menu over 300 km/h (right know 255kmh is the limit)
- Option to let the display flash/strobe with max brightness at a certain rpm (gearshift indicator)
Show graphs directly in utcomp app, not just .csv file would be nice!
toho
Postby toho » Sat Mar 05, 2022 5:51 pm
Bug in v3.8.0
After activating oscilloscope für certain adc (adc5 gear indicator for me), all gear Indicator Settings are gone.
Request for Update:
Add gear indicator to datalogger, at the Moment i cant choose gear indicator in bank 0 - 9
And also My Last Post, especially shifting indicator would be nice, just let the Display flash very fast at a certain rpm.
Ps: love my utcomp! Best greets from germany
JaapStruyk
Postby JaapStruyk » Mon May 23, 2022 6:22 pm
More channels to datalogging in favor of speed, in total there is a max of 17 sensors signals which can be recorded not counting the conditional outputs and timestamp so maybe an extra option for 20 every 200ms? (still within the 10x10 limit)
snaxxi
Postby snaxxi » Mon Feb 20, 2023 1:33 pm
Pistou wrote:Hi :)
I have the boost pressure and fuel pressure measured... I'm looking for exact fuel pressure !
Can you add an option (in fact if everyone would get boost and fuel pressure that'd be standard ^^):
- Pressure measured by fuel sensor MINUS Boost pressure ?
=> That's the exact fuel pressure for turbo engine but still you need these 2 parameters !
I really need that feature too. Really tells you when your fuel pump is degrading and prevents engine damage.
One concern is that fuel pressure will be zero before the fuel system is primed or the engine shut off.
