MX25L12873F Q SPI support
j911
Postby j911 » Thu Dec 14, 2017 11:34 am
I'm trying to read the following chip which supports Q SPI flash. When I try to run Q SPI read, it says it can't find any registers and to you use custom script.
I took a dump of the firmware on the chip and erased the chip and the re-flashed the dump back and the laptop boots fine. However, when I flash a modified bios it doesn't work.
I noticed when I flash the patched bios dump it passes verification, once I power up the laptop and it fails to boot, if I try to do another verification test it fails.
Could you please assist in reading and setting the Q-SPI mode.
Re: MX25L12873F Q SPI support
Postby ArT » Thu Dec 14, 2017 11:57 am
I can prepare you custom script but if you have not changed QE bit than reading/writing FLASH will not change it (it stays enabled when it was enabled before), so I think that your modified bios file is wrong and that's why it is not starting (Quad Enable configuration bit is not stored in FLASH area - it is stored in status register which is not modified during erase/write operations)
Anyway, please check this application file:
https://www.dropbox.com/s/hnt8u4u3amkrc ... S.exe?dl=0
Replace "REVELPROG_IS.exe" in installation folder (by default it is C:\Program Files (x86)\REVELTRONICS\REVELPROG-IS) and run application and run Quad SPI tool again. Does it read QE bit now? Please let me know.
j911
Postby j911 » Thu Dec 14, 2017 8:08 pm
The new execuatble does read it and the enable button is greyed out, assuming that means that Quad SPI is set to enabled in the register?
Postby ArT » Thu Dec 14, 2017 8:25 pm
Yes it means that QE bit is enabled and you can only disable it. As I wrote before if you did not changed registers by custom scripts before than QE configuration is not changed during erase/write operation. I think that your bios is not modified correctly and that's why it is not working (assuming that original dump is working).
j911
Postby j911 » Fri Dec 15, 2017 11:21 am
Yes, the original bios does work fine. All other lptop models work just fine, it's just this one particular model I am having problems with, which has MX25L12873F chip.
