Command line usage for automated programming
PIDEU
Postby PIDEU » Wed Jul 10, 2019 12:33 pm
Revelprog IS using the graphical user interface is working fine for me.
However, I'd like to integrate the Revelprog IS into an automated programming environment and need to call Revelprog IS from the command line.
I could not find any information if it is possible to use Revelprog IS from the command line. Is it possible?
If so, do you have some example how to do it?
If not, basic functionality like using a given configuration and then basic operation like read and write would be fine.
Best regards.
Re: Command line usage for automated programming
Postby ArT » Thu Jul 11, 2019 11:10 am
Command line interface is not available. It's GUI based app and it will not work without GUI, it requires redesigning from scratch - maybe in future...
PIDEU
Postby PIDEU » Thu Jul 11, 2019 3:33 pm
Thank you for your answer.
I understand.
That would be very nice. Do you have a plan for such a redesign?
On the other hand: for me it would be sufficient when I just could use the algorithms the GUI is using. It would be ok if I could just call into some DLL and implement the functionality I want in my application on my own.
Is such an approach possible?
Postby ArT » Mon Jul 15, 2019 12:54 pm
Unfortunately it's not possible. It requires redesign, can't promise at the moment... :(
edit: please check this workaround viewtopic.php?f=23&t=913
Users browsing this forum: No registered users and 34 guests
