revelprog hardware probleme
foulou0238
Postby foulou0238 » Fri Sep 13, 2019 7:54 pm
Hello
I have a problem with my programmer buy in October 2018
any idea how can i fix it please thank u
Capture PROG.JPG (40.08 KiB) Viewed 12053 times
Pityu
Been thanked: 7 times
Re: revelprog hardware probleme
Postby Pityu » Fri Sep 13, 2019 8:41 pm
Hello !
Read here: viewtopic.php?f=22&t=401#p2001
I do the same problem and I fix it.
foulou0238
Postby foulou0238 » Thu Sep 19, 2019 3:58 pm
hello
thank you for replay
i change the parts as requested but i have the same probleme whene i put the bios chip to programme i have error ' protection circuit is damaged' whene i do test withouth bios chip all seems to be fine can any one help please thank u in advance
programmer 2.JPG (43.3 KiB) Viewed 12025 times
Pityu
Postby Pityu » Thu Sep 19, 2019 4:42 pm
Hi!
From my knowledge the hardware test, you have to do it without flash or other chip connected.
All 4 buffers have to be replaced! The replace buffers have to be marked with BU245 (please check)
For the third picture attached the test results show that you don't have on your PC USB port +5V, you have only +4.82V, that is OK for your programer to work fine.
foulou0238
Postby foulou0238 » Thu Sep 19, 2019 5:11 pm
Pityu wrote:Hi!
hello friend for the BU245 i replaced the 4 buffers and whene i have the flash chip connected it shows that 4 buffers need to be replaced but the test withouth flash chip passed correctely
Pityu
Postby Pityu » Fri Sep 20, 2019 3:55 pm
foulou0238 wrote:whene i have the flash chip connected it shows that 4 buffers need to be replaced.....
The message before test is clear. You don't receive this message?
Postby ArT » Tue Sep 24, 2019 12:00 pm
As Pityu mentioned hardware test should be done without any chips connected (it's very important!). When you do hardware test with chip connected then it is doing short circuit and drain high current.
