REVELPROG-IS for Linux
Re: REVELPROG-IS for Linux
Postby ArT » Wed Jan 09, 2019 2:56 pm
It can not connect with memory database. It is using SQLite libraries - in such case Visual C++ Redistributable for Visual Studio (2013/2015) is required. Please take a look: https://www.sqlite.org/index.html .
error666
Been thanked: 3 times
Postby error666 » Tue Aug 20, 2019 7:38 am
After going back and forth between Linux and Windows just to use the programmer, I've decided to try one of windows emulators.
Software 1.8.1 was installed using PlayOnLinux which is basically Wine 4.0. All went fine except some libusb0 errors. As a result I get an error "Programmer is not connected"
Debug info:
wine: Call from 0x7b43e223 to unimplemented function winusb.dll.WinUsb_Free, aborting
USB: Device Not Found.
dmesg output
[16935.691616] usb 3-1.2: new full-speed USB device number 6 using ehci-pci
[16935.802487] usb 3-1.2: New USB device found, idVendor=0483, idProduct=5751, bcdDevice= 2.00
[16935.802491] usb 3-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[16935.802494] usb 3-1.2: Product: REVELPROG IS
[16935.802495] usb 3-1.2: Manufacturer: REVELTRONICS
Any advice? Is still possible to run the software on Linux?
Postby ArT » Tue Aug 20, 2019 12:38 pm
It seems that it does not see drivers.
On Windows 8/10 there is the same error during drivers installing and workaround is by installing signed drivers from application with Zadig software (menu help -> Install drivers) but I do not know if it will work with emulator
bigendian
REVELPROG IS on Linux
Postby bigendian » Fri Feb 07, 2020 5:52 pm
Hi all,
i tried this wonderful programmer with wine and .net, couldn't have it working, maybe due to the distribution i am using.
So, it's time this great programmer, robust, reliable and unique in his style have some Linux tool.
So here a first alpfa version:
https://gitlab.com/spectrum70/rvlprog/
╭─angelo at dfj in ~/dev-sysam/rvlprog on master✘✘✘ using ‹› 20-02-07 - 17:52:02
╰─○ ./rvlprog --help
rvlprog v.0.90-g995b1aec-dirty
 (C) 2020, Angelo Dureghello, Trieste, Italy
Usage: rvlprog OPTION... [FILE]
Example: ./rvlprog -r -t w25q32 output.bin
Options:
  -h, --help           this help
  -t, --type           memory type
  -r                   read binary content
  -w                   write binary content and verify
  -e                   erase chip
  -v                   verify binary content against FILE
  -l  --list           display supported device list
╭─angelo at dfj in ~/dev-sysam/rvlprog on master✘✘✘ using ‹› 20-02-07 - 17:52:08
╰─○ ./rvlprog -l
Supported devices :
1. 25..128
2. 25vf010
3. 25vf010a
4. w25q128fw
5. w25q32jv
6. w25q64jv
7. w25q80dv
Read
sudo ./rvlprog -t 25vf010a -r output.bin
Write
sudo ./rvlprog -t 25vf010a -w output.bin.bak
Erase only
sudo ./rvlprog -t 25vf010a -e
I haven't much time to add other devices, the above are those i could test here.
You can check README.txt for other info.
Let me know if you find it useful,
Bye
angelo
bigendian
Postby bigendian » Wed Feb 12, 2020 9:37 am
Hi all,
added some other device profiles, untested on the real chip but they should work.
╰─○ ./rvlprog -l
Supported devices :
1. 25..010
2. 25..016
3. 25..020
4. 25..032
5. 25..040
6. 25..05
7. 25..064
8. 25..080
9. 25..128
10. 25vf010
11. 25vf010a
12. w25q128fw
13. w25q32jv
14. w25q64jv
15. w25q80dv
Using this tool right now reuqires compiling it. Even if quite simple, i will try to provide the debian .deb package at least.
If anyone would test/use it, please provide me feedbacks here, so that i can fix things, as my spare time allow this.
bye
angelo
bigendian
Postby bigendian » Thu Mar 19, 2020 5:58 pm
Hi all,
i updated rvlprog for Linux to 0.91 adding some eeproms:
╰─○ rvlprog --help
rvlprog v.0.91-gd6f1563a-dirty
Example: ./rvlprog -r -t fl_w25q32 output.bin
Options:
  -e                   erase chip
╭─angelo at dfj in ~/dev-sysam/rvlprog on master✘✘✘ using ‹› 20-03-19 - 17:59:31
╰─○ rvlprog -l
Supported devices :
1. ee_24..128
2. ee_24..16
3. ee_24..256
4. ee_24..32
5. ee_24..512
6. ee_24..64
7. fl_25..010
8. fl_25..016
9. fl_25..020
10. fl_25..032
11. fl_25..040
12. fl_25..05
13. fl_25..064
14. fl_25..080
15. fl_25..128
16. fl_25vf010
17. fl_25vf010a
18. fl_w25q128fw
19. fl_w25q32jv
20. fl_w25q64jv
21. fl_w25q80dv
Later on will provide autotools build
regards
Angelo
bigendian
Postby bigendian » Fri Mar 20, 2020 12:50 am
v0.91 available here
https://gitlab.com/spectrum70/rvlprog/-/archive/0.91/rvlprog-0.91.tar.gz
Classic autotools build:
./configure
make
sudo make install
ozzieone
Postby ozzieone » Wed Sep 15, 2021 12:07 pm
Hi Angelo,
Is this used to command line programming eeproms.
We want to use a raspi connect to the revelprog with sfp board and program SGP eeproms true a script
Thnks
bigendian
Postby bigendian » Sun Mar 13, 2022 11:01 am
ozzieone,
sorry, i come here from time to time only. From what i know, SFP eeprom are accessible by linux in i2c bus, or through special sysfs. Could you explain a bit more your specific need ?
For who interested,
pushed a 0.92 linux version, added just 24c08
angelo@dfj ~/dev-sysam/rvlprog (master*) $ ./rvlprog -l
Supported devices :
1. ee_24..08
2. ee_24..128
3. ee_24..16
4. ee_24..256
5. ee_24..32
6. ee_24..512
7. ee_24..64
8. fl_25..010
9. fl_25..016
10. fl_25..020
11. fl_25..032
12. fl_25..040
13. fl_25..05
14. fl_25..064
15. fl_25..080
16. fl_25..128
17. fl_25vf010
18. fl_25vf010a
19. fl_w25q128fw
20. fl_w25q32jv
21. fl_w25q64jv
22. fl_w25q80dv
If anyone is interested in new flash/eeproms added, try to contact me to angelo AT kernel-space.org
bigLITTLE
Postby bigLITTLE » Mon Jan 15, 2024 12:11 pm
had to add fl_w25q128jv to the linux rvlprog, so i updated the code
to 1.9.1 firmware.
$ rvlprog --help
rvlprog v.0.93-g494e970
Options:
  -d, --debug          add debug console traces
  -e                   erase chip
$ rvlprog -l
Supported devices :
1. ee_24..08
2. ee_24..128
3. ee_24..16
4. ee_24..256
5. ee_24..32
6. ee_24..512
7. ee_24..64
8. fl_25..010
9. fl_25..016
10. fl_25..020
11. fl_25..032
12. fl_25..040
13. fl_25..05
14. fl_25..064
15. fl_25..080
16. fl_25..128
17. fl_25vf010
18. fl_25vf010a
19. fl_w25q128fw
20. fl_w25q128jv
21. fl_w25q32jv
22. fl_w25q64jv
23. fl_w25q80dv
For who interested,
