Overload protection
Frankyisus
Overload protection
Postby Frankyisus » Wed Aug 03, 2022 11:56 pm
Hi!! I have problems reading the EEPROMs, I am using a SOP8 socket with 25LB64C, 25Q16CV and other models and it does not allow me to read them. It always throws the protection error. I checked with another socket and it has the same problem. No error message if voltage is less than 1.0V but cannot read eeprom.
Thanks in advance!!
Captura de pantalla (2).png (658.66 KiB) Viewed 336 times
Has thanked: 46 times
Been thanked: 136 times
Re: Overload protection
Postby ArT » Thu Aug 04, 2022 9:16 am
How is it write protect pin connected in external circuit and what is current consumption of external circuit?
Frankyisus
Postby Frankyisus » Thu Aug 04, 2022 5:32 pm
It is not connected externally, a SOP8 socket is used.
Postby ArT » Thu Aug 04, 2022 7:52 pm
Pin 1 is on wrong side, please flip chip 180 deg
You are doing short circuit at this moment. Hope programmer is still fine.
Pin 1 should be as dot on picture below green ZIF socket
Frankyisus
Postby Frankyisus » Thu Aug 04, 2022 8:47 pm
It is placed correctly. It was working, some eeprom were reprogrammed and the next day it no longer worked.
Postby ArT » Fri Aug 05, 2022 9:24 am
How about hardware test? Remove chip and adapter from socket and please make hardware test from upper menu tools
Frankyisus
Postby Frankyisus » Fri Aug 05, 2022 5:34 pm
Without EEPROM
Captura de pantalla (5).png (783.34 KiB) Viewed 309 times
With EEPROM
Captura de pantalla (6).png (784.38 KiB) Viewed 309 times
Postby ArT » Tue Aug 09, 2022 1:06 pm
Test should never be done with inserted eeprom.
Programmer is damaged and needs repair, I'm sending you PM with details
