Software Version Not Sync
ucokseparoh
Postby ucokseparoh » Fri Feb 10, 2023 4:59 am
On my previous laptop Revelprog installed with this detail; software version on the top left screen shows 1.80 while at the bottom shows 1.84. Although the versions are different, the programmer does work correctly.
I never update my Revel or my friends Revel which I bought for them due to an incident where (may be it was my fault) my Revelprog was bricked after update.
Now I bought new laptop and want to install Revelprog into it. Should I use 1.80 installer or 1.84?
Thank you,
Best regards.
thankfly
Been thanked: 8 times
Re: Software Version Not Sync
Postby thankfly » Mon Feb 13, 2023 4:22 am
Both are ok, maybe you should uninstall and reinstall the software completely on you old Laptop.
Has thanked: 59 times
Postby ArT » Mon Feb 13, 2023 6:31 am
I recommend to install v1.9 and update programmer. You can also use v1.8.1 with firmware v1.8.0, here is changelog for v1.8.x and there is information where firmware update was required: viewtopic.php?f=23&t=398
ucokseparoh
Postby ucokseparoh » Fri Feb 17, 2023 5:13 pm
Hi Art, thanks for the help. I did as you suggested and everything went smooth and my Revel runs the latest software now.
Thank you,
Best regards.
ucokseparoh
Postby ucokseparoh » Fri Feb 17, 2023 5:15 pm
thankfly wrote:Both are ok, maybe you should uninstall and reinstall the software completely on you old Laptop.
did what you and Art suggested and everything went smooth and my Revel runs the latest software now.
Thank you.
Users browsing this forum: No registered users and 54 guests
