No list of devices - device_list/SQL problem
jgorak01
Postby jgorak01 » Mon Mar 06, 2023 11:17 am
Hi All,
I am trying to read and write some data into TI 25LC128 eeprom via SPI protocol.
I have encountered rather bizarre problem;
I am unable to select any device from the list as I am missing device_list.
After I am presented with the selection screen with no options of devices.
When I am trying to close the window it throws at me an error.
I have to quite , and then software is closing the application completely.
Please see attachments for screenshots.
Would anyone be able to provide me with some solution to this problem?
FYI, I am using a company laptop, is running an anti-virus software in the background. I have not had any problems with any software on this laptop before...
related thread:https://forum.reveltronics.com/viewtopic.php?t=505
The details about exception:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Data Source cannot be empty. Use :memory: to open an in-memory database
at System.Data.SQLite.SQLiteConnection.Open()
at RevelprogIs.SQLiteDB.LoadData(String SQL)
at RevelprogIs.MemoryDB.LoadData(String SQL)
at RevelprogIs.MemoryDB.GUI_DeviceListAddItems(ListBox deviceListBox, String sqlQuery)
at RevelprogIs.MemoryDB.GUI_DeviceListShowTopLevel()
at RevelprogIs.MemoryDB.ResetSelectedMemory()
at RevelprogIs.MemoryDB.button_CANCEL_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4614.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
REVELPROG_IS
Assembly Version: 1.8.5.22534
Win32 Version: 1.8.5.1
CodeBase: file:///C:/Program%20Files%20(x86)/REVELTRONICS/REVELPROG-IS/REVELPROG_IS.exe
System
Win32 Version: 4.8.4605.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Win32 Version: 4.8.4550.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
Win32 Version: 4.8.4084.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Be.Windows.Forms.HexBox
Assembly Version: 1.6.0.22436
Win32 Version: 1.6.0.22436
CodeBase: file:///C:/Program%20Files%20(x86)/REVELTRONICS/REVELPROG-IS/Be.Windows.Forms.HexBox.DLL
REVELPROG_IS.resources
CodeBase: file:///C:/Program%20Files%20(x86)/REVELTRONICS/REVELPROG-IS/en/REVELPROG_IS.resources.DLL
System.DirectoryServices
Win32 Version: 4.8.4501.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.DirectoryServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.DirectoryServices.dll
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
System.Data
Win32 Version: 4.8.4584.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
LibUsbDotNet
Assembly Version: 2.2.8.104
Win32 Version: 2.2.8.104
CodeBase: file:///C:/Program%20Files%20(x86)/REVELTRONICS/REVELPROG-IS/LibUsbDotNet.DLL
AutomaticUpdater
Assembly Version: 2.6.18.4
Win32 Version: 2.6.18.4
CodeBase: file:///C:/Program%20Files%20(x86)/REVELTRONICS/REVELPROG-IS/AutomaticUpdater.DLL
System.Data.SQLite
Assembly Version: 1.0.97.0
Win32 Version: 1.0.97.0
CodeBase: file:///C:/Program%20Files%20(x86)/REVELTRONICS/REVELPROG-IS/System.Data.SQLite.DLL
System.Transactions
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.Threading.Tasks
Assembly Version: 2.6.8.0
Win32 Version: 2.6.8.0
CodeBase: file:///C:/Program%20Files%20(x86)/REVELTRONICS/REVELPROG-IS/System.Threading.Tasks.DLL
Microsoft.Threading.Tasks
Assembly Version: 1.0.12.0
Win32 Version: 1.0.168.0
CodeBase: file:///C:/Program%20Files%20(x86)/REVELTRONICS/REVELPROG-IS/Microsoft.Threading.Tasks.DLL
System.EnterpriseServices
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Screenshot 2023-03-06 100903.png (236.43 KiB) Viewed 5947 times
Screenshot 2023-03-06 101022.png (253.03 KiB) Viewed 5947 times
Screenshot 2023-03-06 100950.png (208.84 KiB) Viewed 5947 times
Re: No list of devices - device_list/SQL problem
Postby ArT » Mon Mar 06, 2023 4:14 pm
REVELPROG-IS application does not have access to memory database file or file is missing.
Please check if file device_list is available in location "%appdata%/REVELPROG-IS". If file is missing - please reinstall the software with admin rights. If file is there - something is blocking access to this file (other software) - please run REVEPROG-IS with admin rights or unlock REVELPROG-IS access to user files and it will work.
